As some of you rember the saturn i bought for $1250 had some wacky idle problem... I did a tune up and upon pulling the plugs i found 2 black and 2 white
. I did a compression test to find two dead cyls. I thought head gasket and was told by a shop it was $1100 to fix. I figured it wasnt worth it and it was time to see what i had learned from working on the stang and probe doing small things over the last 2 years.
1999 Saturn Sc2 3 door sport Coupe!
109k on the clock.
5 speed
KBB value: $3995
Problem:
After finding no compression i decided to pull the car in to my garage and pull the head.
After pulling the head i was puzzled.
The head gasket looked fine...
So did the block....
I flipped over the head and found...
2 burnt exhaust valves... I looked around for a used head but then id figured i might as well just get some new valves put in... $510 later i now have a fully rebuilt top end with all new valve seals and guides. The guy at the machiene shop said more then 2 valves were on their way out... so replaced most of them.
I Picked up a new head gasket and new head bolts and went to work putting the head back on.
When installing the camshafts 1 bolt would not torque past 100in/lbs... it broke in the block....
i was able to get it out now im waiting for 2 bolts to come in at the saturn dealer...
But so far i guess Ive done alot with what little i know. My grandfather has been helping as well... neither of us have a clue
i wonder y the vales burnt... the guy at the machiene shop said its a common problem on saturn dohc engines... he also said that it looked like the engine had head work done b4 he found that all the intake side looked beand new...
. I did a compression test to find two dead cyls. I thought head gasket and was told by a shop it was $1100 to fix. I figured it wasnt worth it and it was time to see what i had learned from working on the stang and probe doing small things over the last 2 years. 1999 Saturn Sc2 3 door sport Coupe!
109k on the clock.
5 speed
KBB value: $3995
Problem:
