Stock Operating Temperature?
93gtmustang
524
43
49
When you first purchased a new 89-93 5.0 Mustang, where would the temperature gauge read at normal operating temperature ?
It seems that most vehicles temperature gauges read right dead in the middle.
Was this also true with the 5.0's? If so it would be at 9 o'clock which is in the middle.
I can't remember where my gauge use to read before I put in my electric fan.
I know the stock factory gauge isn't that accurate and I should get a more accurate aftermarket gauge.
I just need a starting point for now on where to set my electric fan to come on.
Right now it's set to come on at the line before half and it seems to run a lot.
I have the stock 192 degree thermostat.
Thanks
Mine runs below the middle of the gauge and sometimes goes up to halfway if i run it hard but never above halfway up. I still have the stock gauges though so the gauges could be off.
I think most run below the mid level but the stock gauges can lie easily.
That's because most cars do not have a true temp gauge, but basically an idiot light doubling as a gauge.
Seems the average driver can't understand a true gauge where the temp points to a certain number. Instead, most cars just have the gauge point dead center when everything is perfectly fine. Only time it would move is if there is a problem.
The 5.0 does have somewhat functional gauges....although very inaccurate. At least Ford tried. The stock voltage, water and oil pressure gauge will move somewhat with changes, but they are nowhere near the quality of aftermarket gauges
In 1994, ford went with the idiot style gauge in the Mustang. When everything is fine they point dead center. The 1996 cobra did have a true oil pressure gauge, but ford ditched it in 1997 for an idiot gauge.
My 5.0 tends to run to the lower side of the gauge..maybe the L or A. I have an autometer gauge however, and that gauge shows it runs at 188 degrees.
Mike is right. They build in tremendous hysteresis because when retard car owners see a needle move, they run down to the dealership and ask what's wrong.
All I can say with a stock gauge (which I will generally not interpolate) is that mine indicated 35* F cooler than the coolant really was.
If you're trying to dial in a fan controller without a real gauge, I'd use IR readings or trying to ensure the fan shuts off before the t-stat starts to close as a means of setting thigns up.
Good luck.
IR = Infrared Red. A contact thermometer (or good IR thermometer) can sometimes be useful (more-so than a stock gauge but less accurate than an aftermarket gauge mounted in the stock sending unit location).
mine reads one line below the middle. but 75% of the time it looks like its overheating, its all over the place. i think the gauge is screwy, i plan on a mechincal gauge soon for true, real time readings.
mine runs at 180 driving around in 80* weather and at a dead stop idleing for 10 mins in the garage it went up to 190-195 and this is with an autometer gauge. On the stock gauge it is between the first 2 lines that is supposed to be 150 so we know its not right!
