clutch popping
Your clutch cable might be getting ready to snap. Mine started doing that a day or so before it got down to being a thread or two away from completely breaking. Pull it loose and give it a close look to see if you're at risk. If so, replace it immediately with a FORD "universal" cable from MM and, if you don't already have 'em, a FWA and aluminum quad.
I have the same problem , but it was not the cable , i went under the car and had a friend push down on the clutch and the poping sound was comming from the clutch fork when just about compressed @ all the way , my clutch works fine but it does get kinda annoying , somtimes it will pop and other times it wont . Check your fork out, when i replace the clutch this is when ill check my fork.
I'd take a look at the throwout bearing riding along the shaft. Sounds like the throwout bearing might be binding.
Definitely your quadrant than if you still have the stock plastic one .. especially once you put an aftermarket clutch in that has a little more pressure than stock that plastic thing snaps fast.
Yes, definitely invest in an aftermarket quad and FWA. With any non-adjustable cable, you'll NEED a firewall adjuster to take up the slack in lieu of having the stock plastic self-adjusting quadrant. Some places sell both together as a package combo deal for a few bucks cheaper than buying them separately (UPR and MM are two good sources).
I guess I'm not seeing where/how the clutch fork could make a popping sound or feeling. It's just an arm on a ball pivot. If the ball pivot isn't lubed, it might squeak or something, but that's about all. If the throwout bearing isn't installed correctly upon the clutch fork (without both prongs going under it), then it'd probably howl and squeal and raise hell, but it wouldn't "pop."
If the throwout bearing is getting hung up on a ridge or snag on the input shaft bearing retainer (possibly not lubed enough/properly, or serious wear marks from prior bearing failure?), then that might make the pedal operate less smoothy and feel like it has a "hitch" to it ... but still not likely to result in a definite "popping" kinda sensation or sound.
The plastic quad sounds more suspect to me. Old rusty springs and brittle plastic can make all kinds of crunchy, weird noises and stuff, especially when they start rotting out enough that they're falling apart.
Again, I'd recommend swapping 'em for an aluminum quad and FWA. Even if it isn't the full cause of the problem, it's definitely a worthwhile upgrade, and likely to prevent a future situation of getting stuck in the middle of traffic with a busted quadrant (or, worse still, premature clutch wear from improper self-adjustment).
