you have to take the dash out on the drivers side! its very easy !first you need to unscrew the 2 screws at the top of your dash ! you should be able to see them by looking into the car through your front window! then right around where your knees are the are 2 bolts on each side! undo these blots! pull the plastic cover off! then it should expose the rest of the bolts you need to get the rest off! go slow and easy !! its a bit confusing the first time you do it! just remember the order in which you took them off and put them back on the same! when you get to the gage cluster its self you will need torx bits to take it out! if you need more detailed info just ask but this should get you going!
