Granada Discs, T5 question, Pan Rust Question
65-Fstbk
316
26
49
Vancouver, B.C. Canada
I'm doing the Granada disc swap on my 65 FB. The car I have is currently a I6 but will be converted to the V8.
Is there some sort of sleeve that I can buy that will mate the outer tie rod from the Granada to the inner tie-rod on the Mustang?
Also, I'm thinking of putting a WC T5 into the car. Some say the tunnel needs to be cut and some say it doesn't (:bang:). Too many comments from well meaning people who are speculating....has anyone actually done it and knows FOR SURE? I thought the tunnel cutout on a 65/66 is in the exact spot for a T5.
There is a little floorpan rust right in the seam where the front floor bends up towards the firewall. It has gone through in a few spots but the majority of the surrounding pans are good and I don't want to cut them. Is there a good way to patch just that area? Any ideas?
Thanks for your help.
http://www.mustangsteve.com/granadadiscs.html
The whole article is useful but skip to part eight for your specific question.
It does, but it needs to be clearanced slightly so it doesn't hit. I had to remove about 3/8" of material on the PS of the opening.
You could cut down the replacment pannel and carefully section out the bad piece. Then butt weld it in place. If you're careful, you'll never see it.
Thanks CraigMBA, much appreciated.
As far as the floor goes I was thinking the same. I thought about maybe just laying some FG over the holes but isn't that the cheesy way out?
The article you linked is great and I have seen it prior. The problem with doing the I6-V8 conversion is whether to do it all at once or get the car on the road and then build up later. For example the tie-rods for the I6 cars are different than those used on the V8 cars so if I mate the Granada tie rods to the I6 tie rods I will need to redo again when I change the steering over to the V8 type. But at least I could drive it and have some fun until I'm ready for the swap to the V8 steering right?
What do you think?
What do you think?
I think (if it was me) I wouldn't do the Granada conversion. But if you have to, you can change the outer tie rods to Granada units and get the adaptor sleves from Mustangs Plus. But I don't do projects that way. Not in business, not on cars, not on my house, not at all.
Here's how I do it.
1. Write down everything that you'd like to do. Try to come up with as complete a parts list as possible.
2. Budget time/parts/money to each thing you'd like to fix.
3. Break it up into functional areas and work on it as you can afford it and have time. To me, not driving a car between steps isn't a big deal, but for some it's a real deal breaker.
One could reasonably assume they wanted to:
1. Do the brake swap and axle swap and wheels and roll the fenders. Drive for a while while you look for other parts and save $$$ for #2.
2. Swap the drivetrain. Redo all the wiring and plumbing. See #1.
3. Change the seats and do the interior less the headliner. See #1.
4. Do a full rotisserie resto on all the cosmetic stuff since the drivetrain is all fixed up.
When they build full on pro cars, they do a "dry fit" where they literally do everything but drive the car. Sometimes they do that. They then dissasemble the whole car (!) and paint it because they know it won't puke when they go to start it. It takes about 40 man hours extra to do it this way, but it saves hundreds because you didn't forget about the parking brake handle or the seats that hit the roof or any other teething pains.......
I used the Granada disc brake swap and am completely satisfied. I bought the disc setup with spindles and rotors off ebay and went to MustangPlus for the rest of the conversion. They have the tie rod parts and the brake lines needed to complete the install. Cost $300 complete!!!
I installed a '95 T-5 in my '65, which is about 3/4" longer than a Fox (87-93) T-5. The shifter is in exactly the right place to come up through the stock floor opening, and no trimming was required. That's what I know for SURE.
I've HEARD that trimming is generally required with the Fox T-5, although not a lot.
Granada Conversion - Tie Rod Sleeve
I changed my I-6 front end over using Granada spindles. I just changed the whole steering to V8 at the same time. Inner/outer tie rods, draglink, and Idler all at once. No need for shims.
The only tunnel work I had to do when I put in my T5 was to open up the shifter hole a smidge.
www.midnightdsigns.com/james
Question for you....do the outer tie rods from the Granada set-up fit the standard tie rod connector sleeve to the inner Mustang tie rods or is a special sleeve required?
I'm doing exactly the same thing you did.
