Look at all that intercooler-brick room hidden away in there.
This car will eventually get some type of squeeze, but as of now it's my daily. I've had plenty of high HP daily drivers - hell I bought a '19 GT new and it was my daily before the CO GT. With a few simple mods it was a high 11 second car (6 speed manual not 10spd - those things were even faster) - during the COVID / price insanity I sold (not traded) my '19 to a dealer for a bit more than I paid for it new - and it had 35k miles on it.
The '04 is actually more fun as a daily. Granted the seating / driving position of the '19, especially on road trips was miles better. But most road trips we take my wife's daily - a '13 Camaro SS ragtop.
Got the car back together. A buddy dropped by the shop later Sunday afternoon, giving me grief I wasn't done yet. It was raining all day, so to me, perfect time to be in the shop. Apparently, cleaning individual fuel injectors, (I have a little rig to hook them up on battery and spray cleaner through them), cleaning out the fuel rail, cleaning / conditioning / greasing the coil boots etc is not considered "Normal" when doing an intake swap.
For both the Ford 'Performance' Intake M-9424-P46A and the Summit intake (they are IDENTICAL - down to all the hardware and the apparently AI Assisted written instruction sheet that is a bit murky) one of the complaints I saw involved hardware.
Several people griped about the threaded inserts for the bolts holding the coil packs were either 'not present' or they easily stripped out. Well they do provide new bolts for the coils. And after seeing the condition of the threads of my original bolts (coil packs, fuel rail, intake etc) I wonder if they cleaned the threads up.
Oh yeah, apparently I am OCD because I have a 25+ year old thread restorer kit - I simply clean old bolts and run the thread cleaner over 'em. FYI you can make a thread cleaner / repairer for nothing just take an old nut and cut a line inside the threads along each flat. But I digress.
The other gripe was the two bolts for the EGR regulator / solenoid bracket where it bolts to the intake. They don't have threaded inserts. The kit comes with two self-threading bolts. I didn't have an issue with them - but I bet over tightening them / not starting them straight in the hole could cause some grief.
There is no fifth bolt for the front extension on the plenum - the four main holes are threaded inserts. The fifth needs a self tapping type screw that did not seem to be included. I will probably pick one up - but the four bolts holding it in right now is super solid - maybe that's just me.
Two spacers were included to reuse the original '04 alternator bracket - since the coolant crossover sits a bit lower than OE - because the crossover is 'by itself' where it meets the cylinder heads - the plastic part of the intake manifold is not under it as it was with the OEM PI intake. (To me that's the best part of this new intake).
New belt tensioner, both idler pulleys, belt, water pump, radiator hoses and rear heater hoses.
Honestly the hardest part was fighting the OE hose clamp on the lower radiator hose at the engine. The angle was ridiculous. On the new hose it's setup so I can easily get to it. Filled with coolant, cranked it up....
And it runs like CRAP.
I'm thinking "maybe the ECU needs to get used to the new intake" - idles up, then down, then almost dies. As I'm going through all what it could be, I realize it has all the signs of a big vacuum leak. No Check engine lights either. Turns out not hooking up the vacuum line on the back of the plenum is bad. LMAO.
Get it up to temp, bled the coolant system and called it done.
