before you start, get a soap pen or something you can mark "0" and what ever degree you want to set your car to on the harmonic balancer. makes it easier to see when adjusting the distributor. loosen the distributor bolt enough so you can twist the distributor. don't take the bolt out all the way though. there is a spout connector you must pull, hanging on the harness right by the distributor. if you don't pull it, the ecu will re-compensate for the timing adjust. when you're ready, hook up the timing gun and start your car. aim the gun at the balancer, you will see the markings. turn the distributor until the pointer is pointing at the mark you made, then retighten the distributor bolt. put the spout connector back in and check the timing again to make sure it didn't move when you were tightening the bolt back. then your done! when you advance your timing, your idle is going to raise a bit, just adjust it back down. also, make sure your TPS is set to .98 - .99v. generally, our cars like the timing between 13-16*.
no you've been pulling the right one. the one in the picture is from an sn95 car. the only picture i could find on google image search. lol. i was just trying to give him an idea of what to look for.
INmemoryJBC8102 said:
how do I check the volts of the tps? obviously a volt meter...but unplugged or how? Thanks for the timing info!
