I agree with the above, not everyone has the money. If he has $3,000, he can have fun with it, by adding power. I have been, there and done that.
I think the Trickflow kit is the better bang for the buck. Maybe to save a little dough, you could ask your summit salesman to 'not include' the valve covers
Or you could piece it together your self, and here is what it comes with and ac couple options
Trickflow H/C/I Combinations:
Street Heat Kits for $2,450:
TFS-K514-350-370 - Street Heat Intake/Street Heat Heads (smog provisions).
TFS-K514-350-370B – Street Heat Intake/Street Heat Heads, Black Upper Intake and Black Valve Covers (smog provisions).
That kit includes:
TFS-51402000 - Stage 1 Cam
TFS-51400510 - 1.6 Ratio, 3/8" Stud, Set of 16
TFS-21406700 - Pushrod Set of 16 -6.700”
TFS-51400904 - Head Gasket Set
TFS-51400801 - Cast Valve Covers or TFS-51411801 for Black.
TFS-51400004 - Twisted Wedge/Street Heads, Assembled (Kit has Single Valve Spring)
TFS-51500001 - 5.0L Street Heat EFI Intake Manifold
ARP-154-3601 - ARP Head Bolt Kit
TFS-51400800 - Oil Fill Kit
TFS-51478520 - Billet Timing Chain Set
FEL-TCS45449 - Fel-Pro Timing Cover Gasket Kit
Track Heat Kits for $2,500:
TFS-K514-360-350 – Track Heat Intake/Track Heat Heads (no smog provisions).
TFS-K514-360350B – Track Heat Intake/Track Heat Heads, Black Upper Intake and Black Valve Covers (no smog provisions).
TFS-51400510 - 1.6 Ratio, 3/8" Stud, Set of 16, ask for 7/16” stud if wanted.
TFS-51400004 - Twisted Wedge/Street Heads, ask for track heat head upgrade confirmation.
TFS-51500001 - 5.0L Track Heat EFI Intake Manifold
Extra Notes:
The street heat intake has 15 inch runners and the track heat intake has 12 inch runners.
The street heat heads come with smog provisions and the track heat does not. The track heat heads can be ported a bit more because of this.
Both the street heat and track heat heads come with 3/8” rocker studs and the track heat heads can be upgraded to thicker 7/16” rocker studs. Just call your sales representative to get the upgrade.
Both street heat and track heat versions have the option to come with dual valve springs and 10* locks.
Twisted Wedge and Street Heat Heads are the same, not to be confused with Track Heat.
The trickflow h/c/i packages are more designed for the fox-body cars do to valve cover tallness and throttle body adapter plate not being included.
So you are looking at roughly $2,500 (shipped), so you have about $500 to get some injectors and a calibrated MAF. New, those parts will take out that left-over account.
To open it up you could put money for later, towards new exhaust/gears, which will open it up considerably.
Good Luck.
