Build your 5.0
91foxbod50
486
Hey guys Im not sure if this is the right place for this thread. But whats the best way to get maximum power out of a 5.0, i was thinking a heads cam intake and 75 shot of nitrous would do the trick. But i have 3,000 to spread out ( I know its not much) But if its invested right, why not
IF IT IS GONNA BE A STREET CAR PRIMARILY TRY TO KEEP YOUR HEADS AROUND 165 TO 180CC TRY TO KEEP THE CHAMBER SMALL THE BUMP IN COMP. REALLY HELPS SEAT OF PANTS. GET A CAM SOMEWHERE IN THE .500-.550 RANGE WITH 220 OR 230 DUR. AND AN INTAKE GOOD FOR 6,000. MY 2 CENTS: AFR 165 STREETS, A CAM SIMILAR TO A MOTORSPORT X, AND A CHEAPY EXPLORER INTAKE SET OF 24'S AND A MASS TO MATCH THROW IN SOME 4.10'S AND BLASTY BLAST. PLUS THE EXPLORER ALREADY HAS A 65 TB ON IT.
I agree with 88mouse, it doesn't matter so much how much power you have as the ability to get the power to the ground. I would start off by getting the chassis/suspension/drivetrain ready for more power. Everyone always likes to do it the other way around and then gets pissed when they can't get traction, or the body starts twisting, or they brake the tranny/rearend. I'd start out by getting some subframe connectors, rear controls arms, rear gears and differential, new driveshaft, and upgrade the tranny. You'll be able to feel the difference in the handling. The rear gears really make a difference in the seat of the pants feel of driving. Plus when you get an engine that can put down some serious power the car will be ready for it.
X2 It sucks when you get it running real nice and say to yourself, "Da8n this thing is fast now!" then snap..."Mother *#*&^ I guess I'm buying a new transmission..." Upgrade your breakables then make the motor to almost break those.
Don't you just love it when you ask for information about an HCI and everybody and their brother wants to talk about suspension, brakes, and everything else under the sun like you're made of money and can just knock it all out in a weekend? That's awesome!
If I were doing nothing but an HCI then I'd probably buy myself a kit that's already designed to work well together. Something like the Trick Flow or Holley Systemax kit. I think that I'd also be tempted to replace the Holley heads with a set of AFR 165s but install the rest of the kit (only because I've heard nothing but good things about those AFR heads and the Holley intake).
It might not be cost effective to purchase everything in the Holley kit except for heads though. You'd have to price it all out and see.
I agree with the above, not everyone has the money. If he has $3,000, he can have fun with it, by adding power. I have been, there and done that.
I think the Trickflow kit is the better bang for the buck. Maybe to save a little dough, you could ask your summit salesman to 'not include' the valve covers:shrug:
Or you could piece it together your self, and here is what it comes with and ac couple options:nice:
Trickflow H/C/I Combinations:
Street Heat Kits for $2,450:
TFS-K514-350-370 - Street Heat Intake/Street Heat Heads (smog provisions).
TFS-K514-350-370B – Street Heat Intake/Street Heat Heads, Black Upper Intake and Black Valve Covers (smog provisions).
That kit includes:
TFS-51402000 - Stage 1 Cam
TFS-51400510 - 1.6 Ratio, 3/8" Stud, Set of 16
TFS-21406700 - Pushrod Set of 16 -6.700”
TFS-51400904 - Head Gasket Set
TFS-51400801 - Cast Valve Covers or TFS-51411801 for Black.
TFS-51400004 - Twisted Wedge/Street Heads, Assembled (Kit has Single Valve Spring)
TFS-51500001 - 5.0L Street Heat EFI Intake Manifold
ARP-154-3601 - ARP Head Bolt Kit
TFS-51400800 - Oil Fill Kit
TFS-51478520 - Billet Timing Chain Set
FEL-TCS45449 - Fel-Pro Timing Cover Gasket Kit
Track Heat Kits for $2,500:
TFS-K514-360-350 – Track Heat Intake/Track Heat Heads (no smog provisions).
TFS-K514-360350B – Track Heat Intake/Track Heat Heads, Black Upper Intake and Black Valve Covers (no smog provisions).
TFS-51400510 - 1.6 Ratio, 3/8" Stud, Set of 16, ask for 7/16” stud if wanted.
TFS-51400004 - Twisted Wedge/Street Heads, ask for track heat head upgrade confirmation.
TFS-51500001 - 5.0L Track Heat EFI Intake Manifold
Extra Notes:
The street heat intake has 15 inch runners and the track heat intake has 12 inch runners.
The street heat heads come with smog provisions and the track heat does not. The track heat heads can be ported a bit more because of this.
Both the street heat and track heat heads come with 3/8” rocker studs and the track heat heads can be upgraded to thicker 7/16” rocker studs. Just call your sales representative to get the upgrade.
Both street heat and track heat versions have the option to come with dual valve springs and 10* locks.
Twisted Wedge and Street Heat Heads are the same, not to be confused with Track Heat.
The trickflow h/c/i packages are more designed for the fox-body cars do to valve cover tallness and throttle body adapter plate not being included.
So you are looking at roughly $2,500 (shipped), so you have about $500 to get some injectors and a calibrated MAF. New, those parts will take out that left-over account.
To open it up you could put money for later, towards new exhaust/gears, which will open it up considerably.
Good Luck.
Hey let em catch traction I'll catch yeah at the high end of 3rd gear it sucks to get backdoored. Let em think they won for a couple gears. The 302's in exploders started I believe in 98 or so they also have a good set of heads on them if you could find one GT40-P's
All I was trying to say is that it is better to build a strong foundation first before you start getting radical with an engine. If you talk to any racer they'll agree. Yeah, its fun to start building power by doing the HCI and all the basic bolt on's. Then you get hungry for more and slap on your Nitrous, Supercharger, or Turbocharger. Next thing you know you have a broken tranny, or rear end, or you can't get any traction.
I agree that it is important to get a HCI combination that matches. Doesn't need to be a kit but the components should compliment each other. You don't want to buy a cam that designed for low rpm's and then a radical intake designed for power 4000+ rpm. But I also think you need to come up with an overall gameplan for the car. Is it gonna be a daily driver, street/strip car, drag car, SCCA, etc? What are the power goals? Do you want it NA or Forced Induction? Do you plan on doing a stroker? All of this plays a big role on how to choose to build the engine. Its not just a simple question of how do I make my car fast.
Just my $.02
He said he had 3,000 to spread out.
Here is what i would do.
Buy a set of these,
http://www.tristatecylinderhead.com/catalog/product_info.php?cPath=41&products_id=29
You can get them shiped to your front door for $850. For another $115 they will send you roller rockers. Get a gt 40 intake from the JY or ebay. And a TFS1 cam. Buy a good set of headers. Then buy a set of UPR upper and lower control arm, SFC's, and with what ever money is left over buy the bolt on's.
go with the H/C/I. My friend has an 89 LX, and i put TF heads on it, TF Street upper and lower intake, Stage 1 cam, and some 24# injectors, with a 190lph fuel pump. It took the car from boring, to a crap load of fun on the street! yea, you may want some great traction, but it seems to me that your not drag racing every weekend, so have some fun! I mean ya have to be able to do some 2nd gear donuts and figure eights every now and then right?! haha! I definately agree that you need traction, especially when racing(obviously), but if your going for a mildly modded street car, you will be fine. My buddies car hooks pretty good stock, and you can still roast them off like nobodys business whenever you want. Its not a drag car, so why spend the money to make it hook like one......unless thats your overall intentions. But about a month ago, we threw on a 7psi Vortech......well now he has the traction problem! haha! :shrug:
Do not forget to add in the cost of a mass air flow sensor, injectors, gaskets, bolts, and misc. items. That can easily push $500 in itself.
Good point. The stock suspension is good enough for a street tired h/c/i, you just have to relearn it. SFC's would be the only thing I'd add at this point other than stickys and skinnies, traction wise.
