I was planning to get an offroad H pipe to put on the otherwise factory system. Who's H pipe has the best fit? I don't want any leaks. Will a 2.5" pipe will still fit on the otherwise factory 2.25" system? I remember the answer being yes because they use ball joints. Seems like this is by far the biggest gain, with around 15-20hp for getting rid of the 6 cats.
Does a drop in K&N make any difference? I'm a little hesistant though, because a dirty K&N doesn't flow as well as a clean paper filter. My feeling is, that the factory system is sufficient unless you can say otherwise.
What are the other worth while bolt ons/cheap mods that can be done on a 97GT, 5sp? So far, it is stock to the paper filter.
The first and only time I was at the track with this car (probably 2 years ago), I ran a 14.6 on this otherwise factory car. Kinda made me wonder if it had a chip since my MPH was around 95 which is far above what the car should do, and it often pings on 87.
I don't intend to make this car fast, but I would like it to be a little quicker, get metter milage and sound meaner.
With your car you'd probably have 210-215ish.
