Doing springs tomorrow, wish me luck!!
Good Luck...hope your 3 ton floor jack doesn't tip over like mine did and have a spring pop out. That happened using the "MFE method" After that I bought the right ford tool. $250 for the right tool is a lot cheaper than a trip to the hospital imo. Either way it still sucked, the tool didnt help a whole lot but i felt a lot safer doing it that way
When you put the new ones in the Front, make sure the Springs Pigtail sits inbetween the 2 Holes that are in the A Arms Spring Pocket.
Thats the best advice yet. The very first time I lowered something (a long time ago) I didn't know anything about that. Ended up having to do it twice. :D
I have used the spring compressors (rented), jacks and ratchet straps.
The spring compressor main bolt stripped out and made the spring bounce around inside the fender for a few seconds.
The jack worked great as long as u have a good quality jack with a wide base that won't tip over and take your time and be very carefull.
The ratchet straps were great but a little trickey to position correctly so you could get it back out w/o cutting it.
The above suggestion to use the hose clamps (multiple of course) is what I will try when I replace the springs on the new project.
Overall, a pretty simple task as long as you have the tools and some patience, common sense doesn't hurt to stay safe. Best bet, when removing the spring once u get the jack all the way down, use the longest pry bar u can find to get the spring the rest of the way out. It will have some pressure to it but not enough to shoot out. I will pop and scare the chit out of u, but not go anywhere. Just watch ur fingers.
This is in my opinion hardest on foxes. SN cars, especially new edges have more room and are much easier to do springs on. Maybe it just easier b/c the new edge's are newer and the bolts don't have 20 years of chit on them.
Just my 2 cents from many past experiences. Don't be afraid of it, pretty simple job. Don't forget to get the car alligned after.
Ok here are some teasers at the request of BK and slow95
They should settle a little bit but I love the way it sits. There is a badass rake right now though lol. I didn't take off the wheels and I didn't even use compressors. It took about exactly 2 hours from start to finish. 1.5 for the first then I got the hang of it.
Basically I supported the arm at the kmember, unbolted the two bolts. Lowered it almost all the way, then unbolted the sway bar end and lowered the rest of the way. At that point I just swung around the A arm until the spring came loose, no pry \bars or anything just by hand and I jimmied the new spring and isolators in there. VERY easy.
