Toploader vs. T5 position with aerostar drivesaft?
downpiped
36
Albany, Ga
I just finished swapping in my Versailles and now Im onto getting my aerostar drive
shaft measured and cut to the correct length. Currently I have a 4 spd top loader
and since my rear is geared to 3.50 , in the not so distant future I would like to put in a T5. Is there a significant difference in the position of the toploader and the T5, anything that would place more error on the measurement of the aerostar shaft?
the overall length of the T-5 is longer due to the input shaft. When I did my C-4 -> T-5 on my '68 i shortened by 3/4" and it fit perfectly. I've heard 1/2" up to 1". But I just looked at the situation with my drive shaft as it fit (or rather, didn't fit) to the T-5.
They had to cut my shaft when I intalled th t-5. If you go t-5 get the bell-housing for the t-5. You will not need the adapter plate plus you can go cable or hydraulic much easier.
