Code 42
dcurtis
688
Ok, I changed my right side O2 the other day, I had been getting a code 41 since I got the car and just now got around to trying to fix the code 41, upon removal of the O2 sensor I noticed all 3 of the wires were frayed out touching each other, and the I think it was the black wire was just all the way disconnected from the O2, so anyways I got the new O2 sensor, put it in, drove the car for maybe 2 minutes, came home, pulled codes and got a damn code 42:bang: , I rechecked the codes one more time right after that and did not get the 42, so I thought maybe the car wasn't warm enough during the first test or something and the 42 was gone, I checked the codes again today after about 30 minutes of driving and the 42 is still there, so what could be causing the 42?? The thing was saying the signal was always lean, now with a new sensor it says it's always rich(no switching), I'm pretty stumped now, what do I do now?:(
RYC CUKR is having the same code, here's what I told him...
Code 42 & 92 (engine running) System rich - Fuel control or (memory) System was
rich for 15 seconds or more (no HO2S switching) - Fuel control. Look for leaking injectors,
fuel pressure too high, cylinder(s) not firing due to bad ignition.
Testing the O2 sensors
Measuring the O2 sensor voltage at the computer will give you a good idea of how well
they are working. You'll have to pull the passenger side kick panel off to gain access to the
computer connector. Remove the plastic wiring cover to get to the back side of the wiring.
Use a safety pin or paper clip to probe the connections from the rear. The computer pins
are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire).
Use the ground next to the computer to ground the voltmeter.
Fuel pressure OK, the injectors are not firing, OR one or more injectors stuck
open
Do a cylinder balance test: Warm the car's engine up to normal operating
temperature. With the Engine Off, Key OFF, use a jumper wire or paper clip to
put the computer into test mode. Start the engine and let it go through the
normal diagnostic tests, then quickly press the throttle to the floor. The
engine RPM should exceed 2500 RPM's for a brief second. The engine will shut
off power to each injector, one at a time. When it has sequenced through all
8 injectors, it will flash 99 or the number of the failing cylinder such as 22 for
cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause
the test to re-run with smaller qualifying figures. Do it a third time, and if the
same cylinder shows up, the cylinder is weak and isn’t putting out power like
it should. See the Chilton’s Shop manual for the complete test procedure
The red wire on each injector is powered up whenever the ignition switch is
in the Run position. The computer provides a ground to complete the circuit
and fire the injector. The injector must have a ground to squirt fuel on
command. A short to ground in the injector return wiring can cause one or
more injectors to be continually open or triggered
A.) A Noid light available from Autozone, is one way to test
the injector wiring. If the light stays on constantly, either the wiring has a
short to ground or the computer has failed
B.) I like to use an old injector with compressed air applied to the
injector where the fuel rail would normally connect. I hook the whole thing
up, apply compressed air to the injector and stick it in a paper cup of soapy
water. When the engine cranks with the ignition switch on, if the injector
fires, it makes bubbles An injector stuck open will release a continual stream
of bubbles. Cheap if you have the stuff laying around, and works good too.
The same trick works great to find leaking injectors too.​
The wiring for the injectors may have some bare spots in it causing the
injector to computer control wire to ground out. This would cause the
injector to remain on anytime the key was in the Run position. Remove the
injector wiring connectors from the injector. Note that each injector has one
red wire for power and a non red wire (wire some color other than red) for
computer controlled ground. With the key off, disconnect the computer
connector from the computer. Use an Ohmmeter between the non red wire
and ground. You should see more than 100000 (100K) ohms resistance.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help wiring http://www.veryuseful.com/mustang/tech/engine/
Using the above diagram, check the resistance between the injector and the
computer. Clean and check the 10 pin connectors since they are a potential
trouble source. Any resistance greater than 1 ohm between the injector to
computer wire and the matching pin on the computer connector is a problem.
See http://fordfuelinjection.com/?p=6 for more help
Here's the link to dump the computer codes with only a jumper wire or paper
clip and the check engine light, or test light or voltmeter. You’ll need it to do
the cylinder balance test
See http://www.troublecodes.net/Ford/
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method.
There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
attachment.php
Is there any kind of a fusable link or something in the 02 harness that could of went bad due to the wires touching each other right before the 02, I think all 3 wires were touching each other since they were all frayed out pretty good and the black wire was all the way broken off. Fuel regulator is fine, will check the pressure on it tomorrow when I get a guage, all cylinders are firing (spark and fuel) , the only thing I think it can be is possibly to much fuel presure, which I doubt, or there's something in the wiring for the 02's, it would make since, since it was reading always lean due to the broken and frayed wires on the 02, so when it got the new 02 with good wires it switched to always rich instead, so I think it has something to due with the wiring.:shrug:
I think you should carefully read through jrichker's post and do what he told you to do.
I dont mean to be rude...but the answers to your problem were already given to you in jrichker's post. He shows/tells you how to test the O2's (both sides) and what values to expect.
Diagnose the problem! Then fix it! Its stupid to just guess at what the problem might be and start throwing parts at it. good luck man
I am going through the entire list JRICHKER posted, I was just wondering if there was anything in the harness to the 02's that could of went bad due to the wires touching each other.
There is a fuse link for the O2 sensor heater power. According to Ranchero50, it is in
the wiring near the passenger side hood hinge. Measuring the voltages will give a clue
if it has shorted to the O2 sensor signal lead. The O2 sensor voltage should switch
between .2-.9 volt at idle.
When checking the voltage, I just pull the computor from the kick panel and stick a needle into the wire to be tested, and ground the other wire from the volt meter to the ground from the putor, do I need to drive the car and watch the meter or do I just let it idle?
Do the above and just let it idle.
I checked my 02s at the computer connector and I am getting a between .44v and .48v on the passenger side 02 and nothing on the drivers side. Actually thats not true I am reading .01v on the drivers side :rolleyes: So I am thinking that that drivers side has taken a dump on me. I am going to swap them today and see just to make sure that it is the sensor and not the wiring.
I did check and I have 12v and ground to each 02 sensor so I know that I have good power and ground to each one. Hopefully I will be able to report back and let you know if it is wiring or a bad sensor later tonight.
