aerostar aluminum driveshaft swap!
sorry guys i cant figure this out ! i have the pics but dont know how to post them!
Find a free photo hosting site - do a google search on photo hosting. I use www.sharedlog.com.
Once your pictures are uploaded to the photo hosting website and you can view them, hover over a picture and right click on it. You'll get a box with Properties at the bottom. Select Properties and highlight the http address and copy it.
Paste the address between the following text string
. The first
tells the Stangnet website that the address is complete and to display the picture.
Sample:
index.php
Be sure that there are no spaces in the text you pasted and the
. If there are, your picture will not display properly.
Some questions about the driveshaft -
What was the diameter - 3" or 3.5"?
What U joints and other parts did you use to make it fit?
it a 3" aluminum drive shaft! haven't been able to find u joints for it yet! i know people have posted the napa 353 but you have to remember I'm in Canada so the part # doesnt match up! they have 2 listing for part # 353 one for a ford truck and the other is for an amc! and they dont have either of them! so there going to order me 2 of each and ill go back tomorrow with the drive shaft and try to find something that is going to work! and as a last resort ill just order the napa 353 off of the Internet in the states and have them shipped to me! but in the mean time I'm trying to install my new 3G alt! i have to find those install instructions again on here!!!
here's a link to a thread i did about my 3g install with a lot of pics. it wasn't a 'how to' thread, it was to verify that i did it correctly, but i did so you can go off that if ya want.
http://forums.stangnet.com/showthread.php?t=722021
and here's Roland's thread.
http://forums.stangnet.com/showthread.php?t=646825
ok here are pics of the install for the 3G alt!
first i had to notch out the bracket so the new alt would fit
here are the supplys needed to complete the swap!
here it is installed on the bracket with the wires hooked up!
then ran it to a 125 amp fuse mounted on passenger side fender!
ran the wire infront of the rad and under my rad support bracket
and out the other side to the drivers side fender!
then put my rad support bracket back on ! hides the wire nicley!
then ran the wire to the solenniod
i know the driveshaft swap turned into the g3 swap! but i promise the drivesaft is coming! i have it ! just waiting on u joints!
well i was going to get around to the driveshaft today but i just relized the drive shaft i have is only 42 1/2" long and im pretty sure i need 45 1/2" long so im going to have to take it back and get my money back! also PM'D Roland to see if he has one he wants to sell! so i wont be able to do the drive shaft till i get the right one! that sucks !:( :notnice: :bang: :fuss: :uzi: :damnit:
ok i got under the car and lined it up and it fits! its 42 1/2" from weld to weld! but from center of u joint to center of u joint its 45 1/2" just what i need! lol ok so now im waiting for the u joints to come in! so i can finish it up! i havnt taken out the old drive shaft yet! any suggestions on how to do it? should i take it right out or try to do it with it on the car? i havnt done one before?
