Fabbed valve cover for SBF?
DK832
291
Copenhagen, DK
I've never had any other covers than the cast FRPP:
http://store.summitracing.com/partd...840125+4294889096+4294903401+115&autoview=sku
Good looking and seals well.
I like fabricated covers too but always disliked the logos (ie. no Ford Racing available) but I just saw another SB with fabricated covers without logos on them. After looking around I only find Summits:
http://store.summitracing.com/partd...6+4294908331+4294840125+4294889096+4294903401
Are they OK? Welding, fit, sealing etc? Any fitment issues on a 351W with Edelbrock RPM heads? They are listed as tall, so I'm guess I'll be OK with my roller rockers and stud girdles?
An alternative is the Moroso:
http://store.summitracing.com/partd...889096+4294903401+4294900056+115&autoview=sku
at a lot more $$ + with a small logo :nonono:
I like Auto Works Racing covers, but for any of those covers you'd still need to fabricate a oil fill/breather hole, including a baffel. Are there any plain aluminum covers that include oil fill/breather holes out there?
Do you know whether these Mr. Gasket "baffled" breather grommets will prevent oil leaks?
They're $5.75 a pair at Summit. Summit also sells a copycat under its own name for $1.50 each.
There's also this valve cover breather clamp from Wysco, pn WA6090, $23 apiece at Jeg's (pn 938-WA6090):
This looks like it would provide a totally oil tight seal at the valve cover surface, and the added height would prevent any blowby oil from coming out the breather or at the supplied O-ring that the breather plugs into.
Finally, there's this Trick Flow oil filler tube kit, pn TFS-51400800, $30 at Summit.
This tube is so tall that no blowby could come out the top. So the only leaking source would be at the grommet at the valve cover surface.
