Hey folks... got a problem here, but first some history that may help:
1967 289 coupe
Last summer I put AFR heads in the stang, along with an MSD distributor, spark box, and optima red top. A couple months later I noticed the battery was dying. I had it tested and it was fine.
Then the car wouldn't shut off! I would drive it, park it, and turn the key off and the car would still run with the key in my hand. It ended up being the voltage regulator, I replaced the alternator at the same time along with new alt. wires going to the celenoid and ground.
The battery was still draining, so I looked through the wiring and found a short, fixed. Everything seemed fine until yesterday.
Got back from the gym and pulled in my driveway... key in hand, car still running. I was on the phone so I turned the car off with the kill switch and forgot about it until I went to start it this morning... dead battery.
So I'm out of ideas. The only thing I was thinking is that maybe the voltage regulator can't keep up with the rest of the upgraded parts. Should I maybe upgrade the voltage regulator? or maybe even get an alternator with an internal VR?
Thanks in advance for any help!
Joop
1967 289 coupe
Joop
