Clutch Cable (3rd one gone bad)
93 LX
3,081
Norwalk, CA.
I have a stock clutch with a Fortes quad and firewall adjustor. The issue is with the cable, the case splits and then the clutch becomes hard to depress. This is the 3rd one that had done this. I have tried aftermarket replacements and this last one was a FORD or so they said it was, wasnt in a FORD package. Any one have any good sugestions? BTW the stock one on the stang broke at the stock quad before the clutch change.
Allen
its routed the stock way. I have 2 fox cars with 5 speeds and they are both the same. The case splits at the tranny then works its way towards the front of the car.
No pics sorry.
Allen
If you disconnect the cable at the fork, does it move smoothly in the sheath? It kinda sounds like perhaps the cable is binding and then putting too much stress on the cable housing.
What is causing this is kind of a mystery though. Just to be really sure (because some cables are installed wrong before we get the cars), does your cable go under the motor mount ear? You don't have LT's?
Alot of those cheapy cables dont have a good sheath inside them. Spend the dough on a good quality adjustable cable. Your t.o.b might be galding up on the bearing support on trans and causing undo stress on the cable also.
Sorry, but "quality" and "adjustible cable" don't belong in the same sentence. :nono: There might be an adjustible cable available out there that's not prone to fraying and snapping off at the clutch fork end and/or binding up all the time, but I have yet to hear about one.
The "Ford" cable you speak of was most likely an OEM-style replacement, but not an actual Ford cable. I normally don't give a poo about buying OEM brand-name stuff, but Ford clutch cables are an exception because they do legitimately make their cables RIGHT. There's a Ford "universal" non-adjustible cable available from Maximum Motorsports that costs less than half of what most places want for the Fox-specific cable (it was around $75 shipped, last I checked), and it fits exactly the same (actually, a tad better, IMO) - you just have to re-use your mounting bracket from your old one. It has a quality sheathing on it that does not bind and will not split/crack on you, as long as it's routed properly, and the table is wound/braided in a much more sturdy design than any aftermarket cables.
The problom is the cable sheath. Go to your parts store and have them bring you the 3 they have One is the "premium" one is a baseline and have them get out one for a 94 mustang. Look at the casing. Find the one that looks like a emergancy brake cable. You can see the way it is wound. That is the cable you want. The only differance in any of them is the 94 is a inch or two longer. They have one for a 93 listed also that has a differant part number. Parts stores can be a pain. Sadly you haft to know more than the guy behind the counter.
r u saying to get a 94 instead of the 93?
so will FORD still have a FORD unit?
Allen
If you want to pay through the nose on a NOS original Ford cable. I think that even the ~ $60 Heavy Duty Ford Racing clutch cable/fork upgrade kit is a made overseas POS. I went through two of them in the past two years, while the prior two cables lasted a good 5 years or so each.
I got the Maximum Motorsports cable last time and it is a much better cable IMO. So far I have about 6 months on it and no problems.
