- Jan 6, 2008
- 14
- 0
- 0
im debating on getting some 18" saleen rims or some 03/04 cobra wheels (17"),but how much will the saleen rims slow me down? does anyone know how much they weight compared to 17s? thanks yall
None because the tires have a smaller side wall so the weight is the same.
He said wheels not tires.
Yes he did............. But when you install tires the final weight ratio is the same so therefore no change.
ummm, no, that would only be true if rubber (and air) weighed the same as aluminum
but I don't think for a street car it makes a huge difference one way or another
Umm........... You're wrong because less rubber is used to make a 18" tire that is same overall diameter from 17" to 18" which in some cases is up to a 10lb per tire difference.
