wtf ??? motor issues
873Stang
221
riverside
so recently i bent a push rod.........aparently i have a fat oil leak on the oil pan that i didn't know about. but im not getting any compression on number 5 the same cylinder the push rod bent, and that rocker are has really bad scaring on it.
so im guessing the valve bent, what would you say? or i have a hole in the piston.
compression test
1)170 5)0
2)180 6)170
3)170 7)170
4)180 8)170
now the wired thing is that 1, 2, 5, and 8 aren't firing they get spark and the plug sparks but if i get a test light and ground out those cylinders at the cap the idle should change but those four dont. im really confused. and number 8 plug will be brown alittle but the compression is 170 so i dont think the rings are bad?
i also check the power going to the injectors which is good also
if you had a hole in the piston you will have oil all over that plug as well as oil smoke coming out the back. I put my money on the valve. Get an air chuck tht screws into spark plug hole they use them to change valve prrings with. Remove your rockers from #5 and screw that hose into the plug hole. Hook your air line up to it and listen if you got a bent valve you'll here it coming up the intake or out the exhaust.
Bent pushrod;
#1 the valve spring went into coil bind
#2 as Punisher stated, you bent a valve due to piston contact.
Check for coil bind first, and if you don't have clearance at full open that COULD be the problem.
Next, remove the valve keepers, retainer and spring as Punisher described for that leak test. But the test would pretty much be moot IMO if you don't have coil bind since you'll have to tear down the engine to the point of correcting your problem.
k did a leak down test,
cyl 5 80psi
cyl 6 80psi
cyl 7 80psi
cyl 7 100psi
now the raocker arms have bad wear or scaring
and milky oil is going to cyl 5 through the intake its also in the pcv valve
what would you guys say
