i picked up a 95 gts the other day. The motor was supposed to be locked up, turns out it was the smog pump. well the guy had started disassembly of the motor I stopped him at the upper intake. I've reinstalled it hooked up the injectors, and all the other electrical connection etc. im getting a pulse signal to the injectors. using my test light,I hooked the ground to ground to the positive and the needle to the other wire(not the red one) it seems to be getting spark to the plugs had it at number 1. i checked the tps it seemed low but it was dark i need to retest tomorrow in better light. I cant do to much right now cause im injured my buddy is doing most of the work any other ideas?
ive got the explorer motor ready to go just gotta install the mustang upper/lower intake(till i get the money for the elbow for the explorer, anyone have one or a link to a cheap one?) already swapped the pickup,pan timing cover,flywheel, clutch(it was new)etc.. just gotta get my buddy to drop it in. im might clean and paint the motor depends if my back is up to it tomorrow. i did a little today and im paying for it now as i type this
