Yes, I have been in a SC'd car. A stock GT's TC stall is 2400 - 2700 RPM. 3000 - 3200 RPM is perfect for a street driven PD SC'd car. CF SC's do not make the same power at low RPM that the PD SC's do. They will benefit from a higher stall TC. A close friend of mine has a S-Trim 2V Mustang auto that has a 3800 RPM PI Triple Disc TC, that car is a daily driver in the summer. He is actually looking for more stall out of his TC.
With all the mods to your car, all you can get is an 11.64?
Chris's GT with a 8 PSI aftercooled S-Trim Auto with a 4.10 gear and 3800 RPM Stall TC and a lot less mods than you is running 11.70 @ 115. I guess it is a good thing he doesn't take advice from you...
I am thinking of putting a S-Trim on 5.0L Big-Bore N/A 2V TBird that has a 4200 RPM Stall TC. I won't be changing the TC out of it if I do...
Where the hell are you getting your info from? A stock stall is around 1700. Also I think I know where a centri makes power being the fact I have one.
Also don’t talk s**t about my advice and the times my car ran when you leaving out the fact that I let off at or before the 1000’ mark. Do you know how much the hurts your times? Do you know I have one of the fastest stock auto GTs on the boards? Trying to compare a stalled auto car to mine when I didn’t even get a full run in is stupid.
What does this guy 60’? ............................................ I’ve 60’ a best of 1.85
Does he run DRs or slicks? ……………................... I run DRs
Does he have a built tranny? ………………………..I don’t
What’s his weight with driver? ……………………. Im around 3600
Any suspension mods? …………………………..… I’ve got noting
Where did he run the time and what was the tem? ….I ran at 400’ above on an 80* day.
The guy could be diving a lightened car with slicks and ran that time on a 40* day at Englishtown where the tack is 1000’ below sea level. I’m not saying he did but I don’t know. You’re throwing out a time and comparing it to mine and talking s**t and telling nothing about the car.
Saying I have a lot more mods than him, I really don’t have that much as for making power. I have Supercharger, Pulley, Intercooler, Cams, Exhaust, and Gears. So the only thing he might not have that I have is exhaust and cams.
Would you care to enlighten me on any of this?
