Yeah, you read that correctly. I've got FMS C-Springs, 245/45 Tires, 17x8 '99 Cobra wheels, 96+ spindles, Cobra brakes....oh...and WORN OUT struts.
Here's the problem....the front tires GRIND on the fenders under braking, cornering, bumps, you name it. And I mean GRIND...not just touch. The front is sitting about 1.5" lower than the back. (typical for C Springs) But it's just too low. Now, I still need a good alignment w/ my MM C/C plates, but I don't think I can put enough camber on these to clear the fender. So I want to actually raise the front back up a little.
So far I have 2 options....I already tried putting new urethane isolators in (had ZERO effect)
1) Swap in some stock springs to get the height back (cheap, but going backwards)
2) Spend my entire tax return plus some more getting MM Coil-overs w/ Bilstien's. (expensive but moving forwards)
Can anybody think of any other options? I really want to do the coil overs, but I don't know if I can justify blowing my entire return on them.
