dual stage nos?
The O.G.
145
witch city,mass
So im checking out the nx 2 stage plate kit.
how does a two stage work?..compared to just single staged activated numerous times?
some sort of timing device kick in later on after first stage?
can a two stage be used for one stage at first till you become more comfortable?
They'd have to be some small stages, if you're running a stock shortblock. A two stage works by limiting the first stage say, to help with a wheelspin problem through first gear, then kicks in the second stage after you're going good. You can get them setup to use the first stage to get moving, lose that one in favor of the larger second stage, and once you're in your final gear making a run for the traps, activate both stages. Or, you could activate the second stage and keep the first stage going right off the bat, without turning the first stage off. Got a link to the NX kit? I'd be interested in checking it out.
i dont really need 2 stages but a good price on one may be worth it
and how does the second stage kick in
if i understand this correct one stage has say 50 shot,second 150 etc
they both seem like good kits either way and will probably pick one up
Depending on your combo, I think the 2 stage would probably be a bit much. I'm not sure how tunable the stages are, but if you were able to go something like a 50-75 shot, then up to 100-125ish, it could be beneficial. A single stage wet kit may be all you need though. I'm gonna copy this thread and toss it in the Power Adders forum, so you can get some more info outside our section alone.
