I had a new set of Toyo Proxes 4's put on the stang yesterday and all the sudden it feels like the car has more body roll than before and i guess the only way to explain this is to say that it feels like the rear end is chasing the front end when cornering even the slightest bit. Does that make sense to anyone, also the car feels like it has more front end rise when it hit the gas, just kind of weird. Maybe because the others were way worn out and there was no rubber left to roll in the corners but the car handled like it was on rails. One single motion at a time cornering and now it feels alot different. What do you think or have you seen with a brand new set of rubber?
once I install those, I'll use those more to tweak over/understeer, and try to match air pressures front/rear.
as someone mention mold release stuff can effect the handling, air pressure levels & balance front/rear, and tire design (stiffer/softer sidewalls).
