I too was worried about the the heads choking me up top. The heads, my old cam that was designed for a stock stortblock, my 65mm TB that is the 94-95 setup, and my small exhaust led me to believe that this thing would peak in the 5200-5300 RPM range since the old combo peaked at 5500. We did degree the cam in a little differently, and the only changes to the old combo was the addition on a holley systemax intake, the shortblock, and I'm running an AEM standalone now and I ditched the MAF. I was shocked to see just how high this mismatched combo pulled. I made these pulls to the rev limiter and as you can see it was just starting to sign off. I didn't want to rev it much higher with the pedestal mount rockers I run. I will add that I firmly believe that larger heads would have produced higher numbers, and that is a theory that I should be testing soon. I hope to pick up 20-30rwhp with the TB and head swap with no other changes... I hope I'm not being too optimistic. I'm going to continue to work on this NA combo until I get as close to 400rwhp as I can before I put my turbo kit on. Its killing me to see it sitting here collecting dust, but I'm sure the end result will be worth it. Plus a 400rwhp NA 331 is still going to be a blast to drive in the mean time. I just hope I don't run out of injector before I hit that goal as I'm still running my 24's.
