I'm installing BMR EN-1 polyurethane rear end bushing. Trying to get old rubber bushing out. Used a hole saw to get inner bolt sleeve out.
Problem is, I do not know if I need to scrape the rest of the rubber out fo the outer bushing sleeve, or to remove the outer sleeve completely. The outer sleeve the BMR bushing appear to be the same diameter. The remaining ruuber in the sleeve is ridiculously difficult to get out. So is the outer sleeve. I actually think I may need a new outer sleeve anyway, as I tried removing it, with a brass bar and a hammer.......odd that the brass actually dented and dinged up the sleeve. I sure hope this part is removable and Ford has a new sleeve. It would be even better if I didn't need the sleeve.
EDIT:
Sorry, more info.
This is located on the top of the differential. THe diff is cast with this space for the UCA to mount to. THere's a steel sleeve with a rubber bushing. BMR makes a poly bushing to replace this.
EDIT:
Sorry, more info.
I hammer the crap out it.
