wow its been awhile since ive been on here, anyways, got the mod bug agian, looking at a lower intake and it doesnt have a pcv hole on it, is it ok to just do away with pcv or is there another way for this to happen?
If your not running your PVC you need to plug the hole for the PVC in the lower intake, plug the hole in your Cold air (or stock set up) that runs to your oil fill tube, that nipple on the Cold air needs to be plugged. Or if youi want to keep the PVC you need to run closed breathers and one that has the outlet on the end for the rubber tube to connect to your cold air.
