For anyone who remembers carburators...
I'm currently using a 650 dbl pumper on my 351W in my 90' GT (3300lbs w/driver)
I'm wondering if its big enough.
My engine:
-10.5:1 comp.
-Comp Cams 280H cam. 0.512 gross lift, 280 dur.
-AFR 185cc heads. 2.02 int.,1.60 ex., factory CNC porting.
-Torker II single plane intake, match ported.
-MAC shorties,X-pipe, Flowmaster 2.5" catbacks.
I'm running a stock t-5 with 4.10 gears. I shift out at btn 6300 and 6500 rpm.
Does anyone run a similar combination with a larger carb????
I've done the online carb calculations by which I shouldn't be too far off with 650 cfm, but I've also seen crate engines with 750's on them.
My engine:
-10.5:1 comp.
