ok, so i got some new gt40x-303 heads, b-cam, and scorpion 1.6 pedistal rr's installed, i went to clay the piston, and it wouldnt make a revolution, i then took the clay out, same deal, just stops part way, and the clay says it hits.. i tried using a stock pushrod out of the old engine, just to see if thats just what i needed to buy. i made a solid lifter, and thats in there.. so, after i spun the engine, and it stopped, i looked at the mark on the intake valve, and it is pretty centered but maybe 1/8" wide? also... when tightening the rocker arms down, they seemed to compress the valvesprings a good bit... that supposed to happen?
exhaust seems to clear..
(intake)
so, do i need to change my cam, or could it be the wrong size pushrods? thank you.
(intake)
