What is the best way to adjust roller rockers, mine sound pretty loud. Tighten them at T.D.C then back them off a quarter turn.? This is what i hear and I wanted a second opinion before I do this.
With the cylinder at TDC, loosen the rocker arm, and then slowly tighten until you can no longer move the pushrod up and down. Then tighten 3/4 of a turn and lock in place.
He said he has stud mount so Bullit347 is correct
You're flat out wrong.
You do not adjust stud mount rockers with the piston at top dead center. With stud mount rockers, you must adjust the intake valve when the exhaust valve is just beginning to open, and you adjust the exhaust valve when the intake valve has reached max lift and is approximately half way back down to seated. In neither of those instances is the cylinder at top dead center.
Seriously, read the link I provided. Do people even click on these things?
