The copper plugs are technically a better plug for performance but the OEM plug for the 4.6L was a plat plug. The ignition system has been designed for it so technically the differences between copper and platnium is very very miniscule on the 4.6L
The 5.0 on the other hand came OEM with copper plugs and an ignition designed for it. As a result, they tend to be finicky with platniums.
I usually say if the car came OEM with plats, they should be fine with plats. That usually applies to daily driver or stock cruiser type cars. Guys with high HP mods, or other serious modifications won't want a plat plug however....and i don't blame them.
I still have the OEM plats in my car at 57K miles. I have a new set ready to swap in, however my car stills idles smooth as silk and doesn't misfire under load in 5th gear...so i'm in no rush to change them. If i had coppers, i would have had to change them 5 or 6 times already.
It's really up to you and what you think is right for your car
