I have a black magic fan from Fal on my 89GT, just wondering if anyone else has problems with this fan moving enough air.
When i had the stock 302 in it with a 160 thermostat is would run around 180 just like i wanted until it was above 85 degrees or so outside. Then it would run anywhere from 205-215 just cruising. If you pulled hard through the gears it got up to about 220+
After putting together my dss stroker, new thermostat (160), water pump, flushed the radiator very well, and of course the heads are new and different block it still does the same thing.
I checked to make sure the fan is pulling, it is. I have a Ron Davis aluminum radiator with the fan. The temp gauge i am using is an autometer.
I'm just not sure if maybe i need a better fan or what.
Any ideas?
Any ideas?
