New suspension goodies for the Mach!!!
UPS stopped by this morning & brought me the final pieces of suspension for my Mach 1. A full Maximum Motorsports K member & a arm setup. I also included in the pics the heavy duty torque arm & rear coilover kit I have had sitting in the garage for a year awaiting install
....Here is the full list of the new goodies....
-K member
-A arms (with delrin bushings)
-2 point K member brace
-bumpsteer kit (bolt through spindle type for MM k members)
-Spherical rack bushings
-sway bar bushings
-lowered sway bar endlinks
-oil filter relocation kit (required with a MM k member swap)
-heavy duty torque arm
-rear coilover kit with 225 lb hypercoil springs...
Also picked up an MM adjustable clutch quadrant & firewall adjuster, & I will be installing a new centerforce clutch, 03-04 Cobra aluminum flywheel, & new poly motor & tranny mounts.... Cant wait to get all this installed & then my chassis will be finally done....The only other peice I will need suspension wise is the MM adjustable rear sway bar & THATS IT!!! Then I need to pay this SOB off & save up for some boost!!!!
Looks like I will be transferring the stock Mach A arms (better steering geometry than the 94-04 GT), steeda X2 balljoints, & steeda bumpsteer kit, & poly endlinks over to the 95 now.
....Here is the full list of the new goodies....-K member
-sway bar bushings
, ever time i see your sig pic i stare at it for 10 seconds
I said no and he goes "well order me one"
