Overheating Question = Answer?
RXTbone
49
I stopped in to pick up a set of electric fan ties today - and got into a conversation with a track guy about Mustangs and overheating. He stated the following - something I've never heard before about overheating:
He said the problem is due to the lower pulley on the 302's were too large (thus operating the water pump too quickly) - the cooling system is so efficient in moving water through the radiator that it actually doesn't have time to cool.
My thoughts are that the system is under constant pressure - and if it's moving fast through the radiator, then it's moving fast through the engine. The only thing you can change is surface volume on the radiator, and air volume over it.
Anyone heard of this track guys "theory"?
I have heard of that happening when boneheads take out the thermostats. But you can't make a generalization that all 302's have to large of lower pulleys. Overheating issuse can be so numerous and specific to each application.
He may or may not be correct, in your specific application. But the theory is definitely correct.
It takes time to get heat out of the coolant. If it passes through the core too quickly, it can't transfer enough heat. An easy way to tell is to compare the tank temperature top versus bottom. Too much flow, and there won't be a large differential. Correct flow for the circumstance, and you can see upwards of 40*F difference in temperature between the two tanks.
Typically if you are stopped and your car is overheating, your fan is the culprit and cannot pull enough air to cool the motor. If you are at speed and your car is overheating, your radiator cannot reject enough heat to keep your motor cool. Granted there is a balance in there but the thermostat should regulate the water flow. There are some water pumps that just don't flow enough at lower rpms(my Milidon didn't on my 5.0) and at a stop the temp would slowly rise. Underdrive pullies don't help either.
Kevin
Thats gotta be pretty tuff to do with a stock thermostat. I highly doubt turning your waterpump a tad faster on a mustang is going to effect much as to cooling as long as the stat is there.
I would say the #1 reason they over heat is the lack of a fan shroud. How many Mustangs do ya see with shrouds on them.
Your gut fealing is correct (sorry 66Runt).
The speed in which the coolant moves through the cooling system has very little effect on cooling system efficiency.
Often you hear people say "The coolant doesn't have time to cool down in the radiator". By that same logic "The coolant doesn't have time to get hot in the engine".
Cooling system efficiency is a direct result of 4 factors:
- temperature difference between ambient temp and coolant temp
- surface area of radiator
- efficiency of radiator (fin design, material, etc)
- amount of airflow through the radiator.
Clearly you can see that the circulation speed will not effect any of these factors.
Actually you're incorrect 70 bottle fed.
The temperature differential between the cylinder bores, heads and coolant passages is far greater than the air-tube-water correlation. Heat saturation is dependant on pressure, and absorbtion slows as it reaches that peak.
I've spent a lot of time with this issue working for a manufacturer. There is a lot of engineering calculations to get the proper flow rates.
The key is to get enough flow to create turbulence, without creating so much turbulence that you restrict flow.
Engine Cooling Tech
I believe the idea is to move the water at a high enough pressure at a great enough velocity through an efficient enough heat exchanger and expose it to a great enough (and cool enough) air flow. The use of a surge tank and/or swirl pot may be of advantage.
Check out tech from the Corner-Carvers Forum:
http://corner-carvers.com/forums/showthread.php?t=34424&highlight=thermodynamics
Good luck,
Henry V
Didn't read any reponses, but BS on that comment. It is theorectically possible but not common to these engines: in fact, I have never had an overheating problem with any 302/351W enigine, no matter what cam/head combo as long as I used a stock rad. and shroud combo.
Good luck,
Henry V
Be careful Henry. This is a 'Stang forum and can be tech adverse.
Y'all ought to check out Henry's car.
my 68 302 in my 66 was overheating. Tested water pump, flushed block, new lower hose, installed new electric fan, new lower thermostat and replaced read cap. Still didn't fix the problem. The rad looked didnt leak and looked good, but I replaced it and that fixed the problem. I must have had a lot of corrossion inside that was too tough to clean when flushing. Just used a new thicker stock brass replacement. cool as a clam now.
nate
i fought mine for at least two years... it'd run fine for a month then start overheating again. it'd go away and come back. i changed everything, water pump, radiatior (stock style), thermostat, the housing, heater core, hoses... everything. then i just got pissed and got what must be an 9 foot thick fluidyne aluminum radiator. works like a freakin' charm. only problem i have now is it runs too damn cool, no heat in the winter! gotta figure that one out now
Yes, that is well said.
It is not true that water can move too fast through the cooling system and thus not cool the engine.
