boost gauge on cobra
Will there be only one vac hehind the glove?sory to get off subject but also installing a pyrometer.now my brother says he wants it installed around the collector I thought its to be only inches from the cylinder head??
Does the Cobra have a cylinder thats known for detonation or high exhaust temp?mabey just install to watch that cylinder.....?
There's only one vacuum line behind the glovebox that I'm aware of.
Not sure on the install location one would use for a pyrometer.
Cylinders 7 & 8 are the suspect holes on the 03/04 Cobra's due to a poorly designed water passage on the drivers side head.
how do i get the head light switch pull/push knob off?
If you pull the headlight knob all the way out and turn/spin it you'll see a tab where you can insert/press a small screwdriver and release the catch which holds the knob on.
U.M.
