injector tuning?
btlfed91
42
STL
If you go from 19 to 24 lb injectors do you have to tune the computer to the 24's all i knew to do was swap out the tube inside the MAF tube to the right size for 24's but someone else told me that I actually have to tune the computer to give a different pulse width with the 24's.
You have 2 basice options...
1. Trick the ecu, but swapping out the MAF meter to compensate for the larger injector size.
2. Get a J3 chip and custom tune for the larger injectors.
Personally, I feel the J3 chip is worth the effort, even if no other changes have been made.
But, if the plans for the car are relatively mild, then the cost/time needed for a custom J3 chip may not be worth it considering there is little room for improvement via the tune...
In other words...
Recalibrating the MAF may be cheaper, but won't be better than a custom tune.
Are you using a C&L meter?
jason
well thats my thing it drives like crap its got several problems that have been going on since I did my H/C/I swap I went with a TFS setup and went with the 24's just to be on the safe side I've got good fuel pressure and I thought I covered all the bases but it idles horribly...up and down,up and down, then it will die after a few minutes of that and then I put a cage in it and now for some reason if I push in the clutch to fast it will die its got a loud whistle that goes with the idle surge that sounds like it is coming from the back of the engine compartment but cant find a vacuum leak anywhere.Ive been working on it for weeks and cant figure it out so I took it to a buddies shop and he couldnt figure it out eather so he called trick flow and summit tech support and they said that I might need to go back to my 19 lb injectors. Im lost!
Sounds like you do have a vaccumm leak. If it hasnt ran right since the HCI swap and you have the MAF sensor for 24s then I doubt it is the MAF. you might need to clock your MAF sensor (turning it till the idle smooths out) or if you have a vaccumm leak more than likely it will run lean and idle high. I would check around all the upper and lower gaskets for leaks. You could have a internal leak may be why you cant find it. When you try to drive it what do it do? and what do you fuel pressure do?
for the most part when I drive it it runs like a bat out of hell but for some reason since we did the cage now it is backfiring like it is out of time or something but the timing is dead on.I dont have a guage that I can watch while I'm driving and I havent tried it on a dyno.also we tried carb cleaner,propane,and smoke all around the upper and lower and all around the back of the engine and couldnt find anything.what will cause an internal vacuum leak? having a valve to tight can cant it,thanx for the help guys Im ready to sell this damn car!
Valve too tight would keep it open all the time and would make it run like **** on that cylinder. AN internal leak would be a broken gasket in the valley somewhere where your lower meets your heads. I am thinking that you have a gasket problem somewhere. When you put your cam in did you make sure your cam and crank gears were lined up PERFECT and that your motor was at TDC. If not then doesnt matter what your Distriubtor says cause you will be wrong no matter what! Also did you torque your head bolts down tight to the right specs. Go back over everything you done to the car since it last run right and make sure you did everything by the book. Did you cut any corners or did you hit any snags along the way that you might have thought you fixed but maybe not?
I made sure I payed really close attention when I did everything because I didnt want to go back and do this I am 100% sure the gears are lined up right everything was torqued right but I guess it is always possible that I could have a gasket problem somewhere but shouldnt I still be able to find it with the carb cleaner or propane and where would my whining noise be coming from also I am very meticulous with this stuff like I said because I didnt want to do it again so I didnt take any shortcuts
i have 24's and my pressure is at 42 with the hose on, as far as the idle surge, ford made this kit for the iac that mounts between it and the iac p/n is f2pz-9f939-a, i run this on all my stangs with bigger cams and injectors. i also have a c&l 76mm mass air and it idles perfectly with 24's and an x-cam. as far as the whining goes, are you sure the pcv or the spot it sits in on the intake isnt plugged? what about the vaccum tree for the booster and the other ports? maybe it is cracked.
i have 24's and my pressure is at 42 with the hose on, ...
Fuel pressure should be set with the vac line disconnected
I've had a vac leak common to intake runner of #1 and the lifter valley.
The lower intake/head gasket had slipped down when I lowered the intake into place.
Are you getting any Diagnostic Codes?
Did you install the stock Sensor in the C&L?
Have you verified the diameter of the SAMPLE tube in the C&L?
