My nuts are stuck...
BullittStangV8
1,104
NJ
hey guys. I know its been a while since I've posted in the classic's forums, but my nuts are stuck and I need some help.:Zip2: The car is an 89, and I cannot get the two (left and right) upper control arms off because the nuts/bolts that go through the arm, and through the chassis are stuck solid. I've tried: 1) hand wrench 2) impact wrench 3) both of the previous with WD-40. 4) The past three options plus liquid wrench. Still nothing. not even a budge. The bolt which extends past the nut clearly is rusted pretty badly. I really need some advise on whats the next option. As of right now, the nuts/bolts are soaked in liquid wrench to sit over night. Again im sorry this is not classic specific, but you guys always give me good advice, and classics have stuck nuts as well. :D
Mike
I assume you are talking about the rear upper arms, since the '89 doesn't have front uppers from the factory...
See if you can find a "nut splitter"..a divorce or break-up from a long term girlfriend cannot be replaced for said "nut-splitter":D.
Check your local tool supplier/wholesaler, etc..
Jim
what about PB B'laster? Whenever I need to bust a nut, I . . . oh wait . . . . seriously, though, this stuff hasn't failed on me yet. Use it like liquid wrench, but I believe it yields better results.
I took two really rusted nuts off bolts for the IRS differential mount on a Thunderbird (the top main two to the frame). The solution, heat (not a crazy amount), a breaker bar, a long strong pipe on the breaker bar for leverage and two broken high strength bolts. I was able to replace them as they were bolts/nuts holding things together... I don't know that breaking the blots is much of an option to you though. Are the threads rusted away?
I second the PB blaster, but in my case... the nuts never moved despite many applications of solvents and I resorted to heat and force.
well. I got my nuts off :)
A six foot pipe was not an option, as I'm doing this swap in my garage on jackstands by myself. I sadly had to cut my darn nuts off with a cut off wheel. I used the wheel with a small disk to cut a slit through the nut (and some bolt threads), sprayed on the liquid wrench, then went after it with a regular socket/wrench. It took a ton of effort. My impact wrench wouldn't even budge it. Once I got it to turn a half turn though, the wrench spun it off quickly. Overall, its about as much fun as getting kicked in the nuts... :)
Just so you guys know, liquid wrench is FAR superior in performance to BP blaster. Kroil is better then liquid wrench and AFT + acetone is better still. Liquid wrench is the most affordable for its performance and the fact that it is premixed. Kroil is expensive and hard to find. AFT + acetone works the best but you gota pre mix it yourself and then store it.
Here's a link to the Penetrating Oil Test thread a while back.
i have had much, much better results with pb blaster than wd40 or liquid wrench, i've also used the torch and wax trick a few times as well, i had that fail on me for the first time ever a while back though. i was trying to get the idle mixture scews out of a 2100 carb i bought on ebay, they were stuck good. i was able to get one out with just the pb blaster but the other one wouldn't come out with anything, not even the torch and wax trick, it finally broke off and i tried to drill it and use a ez-out on it but even that didn't work, i ended having to get another carb but i used a bunch of the parts from that one since it was the right one for my application. eventually i'll put my muscle parts intake and a 4100 carb on it but i want to make sure it will run right as is before i start swapping parts
