Well, last time i started throwing out prices everyone tried to call me on it (even though i was quoting prices directly off Summit's site) so i won't bother with that again...do a search and you'll find a lot of those threads.
Suffice to say, it's gonna be cheaper. Period. You won't pass emissions so keep that in mind, and you need to know how to tune a carb or you're just gonna make a mess for yourself.
That said, the 2 biggest issues are with the fuel and ignition. With the fuel, the problem is the pump and the tank. Some people say you can get away with using a regulator to regulate the stock EFI pump down to the 6-7psi that a carb needs, but that's a recipe for disaster if you ask me. The right way is to either sump the stock tank and run an electric in-line pump designed for a carb, or even to switch over to an '85 style tank (which may actually be easier and cheaper). You could even go so far as to switch the timing chain cover and run a mechanical fuel pump if you wanted.
Second, the ignition, is a lot easier. You need an EFI style distributor and your choice of ignitions....you could run the stock Duraspark, an MSD box, or even get an HEI conversion and have your ignition right on the distributor for a clean and simple install (i run a Mallory Comp 9000 distributor that has the ignition built in...very simple).
After all that you just need to decide what your ultimate goal is with the car and then you can start picking intakes and carbs and cams etc.
