J&M Products is proud to announce the release of these new direct fit D.O.T. certified Teflon lined brake hoses. These brake hose assemblies use true OEM style direct replacement non-universal fittings to achieve proper factory hose routing and fitment. Expansion of stock rubber hoses causes a spongy brake pedal feel and loss of initial braking force. Installation of our Teflon-lined stainless steel hose assemblies will give your car a firmer pedal, quicker braking response, and easier brake modulation. Every hose is tested to 3000 psi to guarantee a leak free hose assembly. Best of all these are made by J&M Products right here in the USA.
Benefits:
- Direct OEM fit
- Quicker brake response
- Better brake modulation
- Every hose is pressure tested to 3000 psi.
$154.39
For more check out http://www.hotpart.com/index.php?p=show&id=125
Thought you guys would like to hear about these, nice OEM fittings combined with DOT teflon/stainless.
Cheers
Mike
Benefits:
- Direct OEM fit
$154.39
Cheers
Mike
