Brakes 1994-95 Mustang J&M Rear Stainless Steel Brake Hoses GT/Cobra
Swhitney
169
Oregon City
I removed the soft lines from a 94 and newer mustang, then installed these J&M SS hoses, and the hard line doesn't fit. LMR is creating a ticket on this, but in the mean time it would be nice to know what fitting they used? Can I simply cut my hard line and replace it with the correct fitting?
1992 Ford Mustang GT
94 - 04 brake calipers here
11.65" rotor with anti moan brackets
1994-95 Mustang J&M Rear Stainless Steel Brake Hoses GT/Cobra found here
Found that the SS brake line fitting is a 7/16 inverted thread size with 1/4 tubing. The stock line will not fit that fitting since it is a standard 7/16 double flare.
What axle brake line can I do to quickly fix this problem without waiting 10 days from LMR?
I just did this to my rear. i found it easier just to buy all the rear brake lines up to the center line that goes up into the hard line. everything bolted right up no problem.
