So i figure i'd ask since someone out there has to have experience or dyno with this.
I only care about the HP to the crank..i'm on a quest to run 13.9 on stock tires. S197 make 300 BHPand they run 13.9 and weigh about 150lbs more, so i figure if i can make 300 at the crank, i should be good.
Right now, I have:
Accufab 75mm TB
Accufab plenum
K&N FIPK II intake
O/R H pipe
2.5" Catback
Steeda Pullies
Anyone dyno there cars with similar mods or have an idea of how much HP it makes?
I don't want gears or long tubes, So i don't know what route to go now. I've done everything i can think of as far as bolt ons, except a Tuner.
Right now, I have:
Accufab 75mm TB
Accufab plenum
K&N FIPK II intake
O/R H pipe
2.5" Catback
Steeda Pullies
if i remember correctly it was somewhere around dead idle and 1500... possibly 1250... i dont really remember. It was actually fairly cold too. But i was on nearly bald kumho ecsta's at like 25 psi or a little less... i was spinning those tires at the top of 3rd as well and spinning BAD in 2nd. 2.1~ 60' i believe
2500 launch on street tires
