MAF Meter electronics replacement....
93 LX
3,081
Norwalk, CA.
I just picked up a MAF meter from the bone yard that has a 6 pin MAF electronics package. I want to install this on my 93but my 93 has a 4 pin MAF electronic unit. The torx screws has a pin in the middle so I cant use my regular drivers. What kindof driver do I need to remove this.
Also the MAF is from a Mod Motor T-bird that used a rubber host to attach it to the air box so no flanges to remove and the output side (MAF to TB) is the same size as the hose on my 93 Stang.
The part numbr on the MAF electronics is F6SF-12B579-AA and AFH70-02C and 6J26.
Any idea on the specs of this maf?
Tamperproof or security torx bits are what you need to remove the fasteners.
If the housing you got happens to be a 70 MM unit and the tube in which the two MAF wires sit is the same exact size as a 94-95 Mustang 70 MM housing, you might be able to use a 94-95 Mustang sensor in the Mod motor housing.
If the housings are not identical (other than the flange), then stick with a 94-95 housing and sensor (a married pair) and work around the flange.
And FWIW, the later MAFs had IAT functions in them, hence the extra wires. It's easy to rework the wiring connector to use a 6 pin in a 4 pin application however.
Good luck.
Some Images of the MAF
Here are sone pics..more to follow
pics 2....
here are some more.... MAF connector and pigtail. Colors are red, black with white line, grey with pink line and blue with red line..
Pics don't help us much.
If you have the year of T-bird, check the wiring schematic to see what wires do what. If Ford was universal, the conversions guys use for Lightning MAF's might be helpful.
And again, if the housing is the same as a 94-95 Mustang MAF, you could try and swap a 94-95 MAS into that housing. You'd have your easy plumbing connections with a more-correct air-flow transfer curve.
The only other MAF that is a one for one swap for a 93 and earlier 5.0 Mustang is the 94-95 Mustang MAF.
The MAF body and sensor are designed to match each other. Therefore you can't swap sensors between different part number MAF bodies and maintain proper calibration. The assembly is designed to match the computer’s internal program, and swapping a different MAF can upset the computer's calibration. In other words, your monster MAF probably won't match the calibration of your 5.0 Mustang computer.
OK here is what i did. Since everything aligned i used my 93 MAS in the 96 Meter and bang o the machine fired up and runs good. with this MAF I can spin the tires in 2nd from a roll and there seems to be more mid range torque than before. I just ran a 96 Cobra which i have ran before and still got beat but it was much closer than before and my 93 didnt fall on its face in 3rd as it has done in the past. I will try the MAS that came with the Meter after making an adaptor, dont want to cut up the stock wiring unless it works.
Verdict: By the Seat-o-pants meter this is a thumbs up mod. :nice:
Please do not attempt this at home folks :notnice:
And why not? larger MAF meter no modification to MAF meter or rubber hoses, uses stock mounting and if you use the stock MAS no wire modifcation. The car runs great, better throttle response and more mid range power....
i wish i could give you the part number of the meter but I could not find one n the meter at all. I'll find another and give you the car specs. What I do know is it was a T-bird with a mod motor so i guess you may have to just accept that this worked. BTW both Sensors looked identical, same length of the probes and element location as well as the same bolt pattern.
Allen
:stupid: (kidding vristang)
Well...you really don't know what will happen long term with this "mod"...you could be running the engine too rich...or even worse...too lean...:( This "mod" could cause long term effects to the engine...the ONLY way to know how it's running, is to have a wide band O2 sensor setup. The 55mm mass air has a FAR different mass air transfer than a 70mm, this is one sensor that should NEVER be messed with, if you do not know how lean/rich it's running...or atleast have a chip with the proper MAF transfer chart loaded on it, as a safety net...:nice:
Sorry to pee on your Wheaties like that...:rlaugh:
stock motor with 201000 on the clock. Like I am going to invest in a wide band O2 sensor setup. LOL thanks but i will replace the MAS with the one that came with the meter or even pull one from a 94-95 stang.... but for now it works just fine...
If he is using his stock mass air meter then as long as it is in the air stream then the computer will compensate for the increased air flow I have to disagree with people saying its a bad idea, It shouldnt matter what housing the meter is in as long as the meter is in an area it can measure the air flow so i give it :nice:
It's really not that complicated. If the MAF meter is the only thing that's changed, the engine is still moving the same mass of air at the same rpm, load, and throttle position.
If this MAF meter setup is putting out the same voltage signals as the original one was, then the proportion of metered vs unmetered air through the housing is the same, and thus there will be no difference to the A/F ratio. You don't need the expensive gear you mentioned in order to check, all you need is an inexpensive multimeter.
That being said;
93LX it would be prudent of you to take some comparison readings between your two MAF meter setups. Test between pins C and D, and read what your voltage is at idle, 20, 40, and 60 mph. I would also test to see what your max voltage is at WOT. Do this for both setups. The higher the voltage, the richer you're running. Max possible voltage should be ~ 5 volts.
Comparing the results will let you know if you're going richer, leaner, or staying the same with your new configuration. :nice:
LMAO @ you for using ebay as a tech source
Sadly, I don't have the patience to run through the full explanation of how the sensor interacts with the housing.
If no one else wants to explain here, then you guys will have to do a search.
The ecu can only compensate +/- 12.5% on the Fox cars.
If your hoky MAF setup puts you outside that range, then the AFR stays there.
If your hoky MAF setup falls with in that range, then you have gained NOTHING as the ecu will push the AFR back to stoich anyway.
No gain with mismatching MAF housings & sensors... only risk...
The 94/95 MAF swap is a KNOWN alternative, and the results have been well documented by more than some 'seat-o-pants' meter lol
jason
