Well I finally got the car tuned and dyno .Big thanks go out to kurgan motorsports, bob kurgan did the tuning and dyno,I will recommend bob to anyone looking for the best. The problems I did run into were some spark issues with stock ignition setup, so the plugs had to be gap to 22,it help out but i still need to upgrade.I also have the act and methanol nozzle in mix up, so I need to relocated the act and the snow performance methanol nozzle .I left the shop with 483hp 455tq with 13lbs of boost, didn’t want to go further until I fix the issues above, but im happy with that. The conditions were 90 degrees, 29.67 in Hg, humidity: 13%, STD: 1.03. Ill get the dyno sheet up later.
Here the info on the setup
306 with twisted wedge heads
Holley Systemax 2 intake
Stock cam
Ford racing 1.6 rockers
trickflow valve covers with a breather on each side and no pcv
Accufab 70mm tb and spacer
Power adder
Vortech S-Trim with a 2.95 pulley
Snow performance stage 2 kit with maf controller
60lbs injectors
Sct 2400 maf
Anderson 4” power pipe
Exhaust
BBk LTs
Bbk xpipe
Bassani mufflers
3.73s
here is the dyno video
Video of dyno - Photobucket - Video and Image Hosting
jesse
Stock cam
Power adder
60lbs injectors
Sct 2400 maf
Exhaust
BBk LTs
Bbk xpipe
Bassani mufflers
3.73s
jesse
