We used Moly grease on the bearings once and had the same results. Part of it was the main caps being mixed up (#'s 1, 2 & 4 weren't numbered correctly at the factory) Part was the moly grease. This motor had other problems and after disassembly after 50 miles, still had moly in the bearings and oiling passages. Bottom line---in addition to the moly there, did you make certain the rod and main caps were installed correctly? And the rods facing the way they need to be?
