If you can't find the leak, you might try to use a UV tracing fluid. Add the UV dye to the fuel tank and then look under the hood and under the car in the dark with a UV light. Any leaking fuel will glow. Make sure you look with the ignition on (but the engine off) so the fuel pump will be pressurizing the system. Some car parts stores carry that stuff, or they can order it.
