forged teksid
it is an aluminum block used by mark vii's and 96-98 cobras. the early variety is a bit weaker than the later version. but they both can handle 1000hp or more.
as a matter of fact late model aluminum blacks are actaully more desireable. but teksids are plentiful, light, and strong.
well teksid block is apart. amazing how little wear there is on the motors. a little refreshing and it goes back together. no wear on crank or cylinders to talk about.
this thing must have been babied. i am going to sell the pistons/rods/intake/heads/water cross over/oil pump as a 4v conversion kit on ebay. it only needs rings and bearings.
well, i thought that too, and its why i bought this. but some builders are switching. dunno.
what i do know is my rods are good to 1000hp with the good arp bolts. pistons aren't. crank isnt. i may end up pulling iy back apart and using billet pistons and crank and going all the way to 1000hp. we'll see.
i am telling myself i will be satisfied with 550rwhp.
You have manley H beams with arp 2000 bolts? Yeah, i think 550rwhp is a very good mark actually. Well suited for the fuel/ignition/MAF upgrades needed. Don't need a fuel tank sump - with returning fuel system you can just use an in-line pump and 255lph in tank. 62# injectors since they are cheaper than 50#. Don't need fuel rails under 550rwhp.
Post up you part choices for that stuff if you can. Interested and seeing what route you take.
oh.
total tubular front/coil over. qa1 tubulara-arms, granitelli k-member, lakewood 90/10 struts, upr coil over conversion, Qa1 200 in-lb x 14" springs, sway bar delete, tower brace delete, g-bar delete. U.S wheel 15"x 6" -4" backspace steel wheels w/165 80r15 front runners. manual rack, hydro boost delete-manual braking, power steering pump delete. ABS delete is coming soon. granitelli adjustable rear control arms, quad shock delete. welded SS lower torque boxes. rear axles are worn out and will get 28 spline mosers. 275/50-15 hoosier quick time DOT pro drag radials. on 15x8 4.75" backspaced rears. rear end dog-bone delete. lighter than stock 4" FP cowl hood
i changed the 3.90 to 2.73 for economy right now, but i will change that to better gearing after the new motor goes in. i need to see it's fuel ecomony first. 3.40;'s as a maximum though.
i have to j-mod the tranny. better converter with stock stall.
no deletes on anything in the interior, although a passenger seat in place of the power driver's seat in in line.
i just rebuilt the clutch packs in the rear end, and i'm unhappy with its holding, so i am going to modify it for better holding/less slip.
90mm lmaf, 4" aluminum inlet to TB, 6"x11" x4" opening K&N for the turbo. blow-through tuning by me using SNIPER. 36lb injectors at first with 42lb later as boost goes up and intercooler gets added. lowest heat range plugs(i dont recall what brand), ACCEL super coil packs, racing 8.5mm wires. 03 stock cobra radiator. twin 15000 gwvr coolers. cobra radiators dont have provisions for tranny cooling. ported heads. stock 06 3v intake manidols with twin 57mm TB. i am making the TB to manifold adapter/iac setup. i will dyno tune it after i get it running decent.
this motor will be run at near zero boost daily using(dial-a-boost) regular 87 octane fuel. for boost i will run premium for a few days, or just use racing gas.
i am currently undecided on final compression ratio. milling the heads is an option if i want higher than 8.5:1.
you could do this with centri's by removing the belt for daily driving and flashing the pcm for the usage.
the maf will not be pegged blow-though. the injectors at higher pressures will be fine. what ever power level it can run is where it will fall. 255lph pump.
if i have to upgrade i will. we'll see what the limit is.
it's getting down to the wire. i assembled cylinders 1 thru 4. 5-8 tomorrow. gonna finish that and install the windage tray and the lincoln oil pan. BTW the lincoln part is pretty good. it is baffled and has crank scrapers from the factory. the bottom end buttoned up.
next is removing the turbo's factory 5 bolt turbine outlet and making a SS plate with the downpipe welded on. the plate will also be made to mount the turbo to the timing cover with a 90* plate welded on.
also the 3v cover doesn't match up exactly to the teksid. i knew that. so i'll braze the hole that would cause it to leak.
with the turbo mounted I will have to stop there until i pull the 5.4.
i took the above stated advice and purchased some 39lb injectors. i will run them at 3.5 bar. the paxton FMU isnt needed. the tuner compensates the tune so i dont need it. i'll take it to the dyno just in case.
high pressure oil feed with restrictor is in. i bought the largest intercooler (4"x31"x12") and 3" piping i think will fit. 3" BOV pipe with pre welded flange is in.
exhaust still isnt started. but it will be a single 3" and 3.5" bullet muffler 45'd in front of the driver's rear tire. waste gate not vented.
i am going to go carefully on the dyno. sniper assures that the tune is conservative when setting it up. but i'm going carefully. 6 psi then 8 then 10 then 12 maybe a few more.
with 8.5:1 i guess i dont have anything to worry about. but with 2 termi's blown up in the club and other around the area, these pistons aren't fool proof. not really afraid to hurt the rods. they tore up at 17psi on pump.
hate to sound like a puss, but i really cant justify replacing stuff for going to hard. it's funny, when its other people stuff, and it's theory i dont worry. when its mine i think i will be careful.
108 octane and ill push it as hard as i think my tranny/axle/driveshaft can take.
at the track i cant go fast enough to trigger the cage rule. so i have no idea what psi i will run march 29th. i will swap gears for the event. probably 3.40's.
march madness clarksville speedway.
outlaws, street, ricers. pro tree, NHRA ladder. street class is DOT only. usually the fast guy is 6.50's. slow guy is 8.90's. 3 round quals.
if i go to bowling green and throw the sh_t to it they wont let me back. or if i blow the tranny up i will be out for a while. so hey enough is enough.
have you guys read the MMFF article on the 20 psi 3v. 700rwhp. thats too far for me.
as a matter of fact i will probably slow down on the racing after i get a few good runs.
intercooler arrived... 1000hp ready. hotmustang told me to get the biggest i could.
black anodized tubing.
