1990Coupe
No i do know what you mean, but for only 1qt something will definitaly show on the stick.. Maybe 2 or 3 qts low won't show. but 1 qt will show as low on the stick.,
.+1. either there is something you have missed or we are not getting all the facts.I'm with you, the other way I have seen nothing show up right away on the stick is all the oil was still up under the valve covers and the heads had so much crust the oil took forever to drain back down. the double gasket on the filter usually blows oil everywhere right away. something isn't clicking with this story or we are missing something.
did the DIPSTICK by chance blow out of the block some?
I am curious to see what happens though. hopefully the internals arent damaged from oil starvation.
any chance the oil came out through the exhaust?
is there sludge in your exhaust pipes?ive been wondering that. when i first started the car after getting more oil in it it basicaly poured water out the passenger side tail pipe. some oil in pipes. but there is still oil all over the underside of the car. so it may be both.. if it came through the exhasut then it would be what. rings bad?
I wouldnt rule out a bad ring or perhaps even an exhaust valve.
on another note what the hell is a hyperfoosinating valve?
did you check the gasket on the ol filter and make sure there arnt 2 on there...
