What head gasket for 347 stroker?
On the subject of gaskets, if I have a complete shortblock and am going to be putting on my heads/intake what gaskets do I need? Just the head gasket and upper/lower intake gaskets?
I think summit sells a complete gasket kit which might be cheaper for you. IT comes with every gasket for a complete from the oil pan gasket all the way up to the throttle body gasket. has Everything buddy
Cometic Gasket, Inc.
i ran them on my sbf turbo they are the best i have used and they are reusable if u have too. im building a 547 bbf 13:1 motor and im going to have them on it. my friend has them on a 408 with r heads and 3 nos kits is has never put the 3rd kit in it but its ran 8.20 1/4 on 2 kits 1 500 hp fogger and a 125 hp kit off the line on drag radials
They're better. Believe it or not.
Well, i want to know from guys that have been there and done that so thats why i have these questions. What about the copper ring the 1011's have. does the 9333's have these feature as well? Sorry for all the questions. I just hate doing things twice. Sell me on these 9333's
I've seen 9333's on every thing to 9 sec. blown setups to my 10 sec. N/A setup. They work.
9333s have metal rings in them. they are a good gasket i have them, i used them with my blower pushing 13 psi and i never blew a gasket, your tune is going to affect the HG life rather than the gasket itself.
i think there is a myth that boost kills gaskets quicker, IMO what kills them is raising boost without adding fuel or retarding timing. since a blower/turbo raises compression, you become MUCH closer to the detonation threshold, and without retarding timing or adding fuel to control combustion temps, your going to detonate and most likely toast the gasket. its detonation that kills gaskets not boost really. make sure you tune the car or have it tuned good and you will be fine.
people seem to up the boost and blow a headgasket and blame it on the boost pressure, but usually its the lack of adding fuel or taking away timing
i ran 1011-1s for like 30 mins when i had irons heads, but i had the heads off for some other issues so i just went with what everyone said, the 9333s, and i havent had any problems.
plus i think the 1011s are a little thinner gasket which will slightly raise compression which isnt really the ideal thing to do with a blown setup.
1011-1's or 9333's, 1011-2's don't seem to be that "sturdy" based on the pic below. Even though studs were also installed, I won't use 1011-2 HG's..... they were replaced with 9333's and have held up fine.
why arent you running your blower, i thought you just got it on not too long ago?
Yeah i did just get it in may. Honest to god, I woke up one morning and said to myself i want to build up a 347 stroker n/a to see what all the hype is about with low end torque. So i sold the blower and transfered the money right over to fordstrokers.com and had him build me a stroker. Eh, i needed a winter project. Call me crazy, hopefully someday, I will have my mind setup lol.
