Yes, I put in power windows/locks on my car when I got a much nicer power interior. Everything swapped in just fine, but it did take a bit of work. Remove the manual regulators and install the power ones, install the lock actuators, run the wiring through the door and install the rubber cover in the door opening (mine was a PITA since I couldn't get the car side to fit right). Then you need the wiring harness from door to door, it runs right below the windshield under the dash, and connects to the main harness with a two wire plug in the driver's kick panel. Then you need the power window circuit breaker for the fuse box, it is a silver rectangular box.
Good luck!
