I have been trying to track down my surging idle issues and was checking out all of my vacuum lines making sure there were no leaks and noticed that there is no vacuum line hooked up to the PCV valve. I know there is suppose to be a vaccum line running from the upper intake to the PCV valve, but this is where I get confused. The valve cover has a spout on it, that has another PCV valve in it (attached picture) and is attached to a vaccum line leading into the upper intake. The valve cover on the other side has a breather on it (attached picture). Is this hooked up wrong or can I just leave the PCV valve in the upper intake and plug it?? Since its not a stock intake or valve cover I am not sure what is correct, but the PCV valve just sitting in the upper intake with nothing connected to it, can't be correct...
